Tire size?
Old Dec 24, 2004 | 12:10 PM
FastZ8's Avatar
Tire size?
I have 17x9.5 ZR1's on my 94Z hardtop. Is it possible to stuff a 315 under the back fender wells without rubbing or having clearence issues.
Old Dec 24, 2004 | 12:47 PM
nin97's Avatar
Re: Tire size?
correct me if im wrong but i dont think you can fit 315s on a 9.5inch rim can you?
Old Dec 24, 2004 | 02:20 PM
FastZ8's Avatar
Re: Tire size?
if I can fit a 295 on a 8" rim a 315 must be possible on a 9.5" rim ??
Old Dec 24, 2004 | 02:30 PM
ShawnMacAnanny's Avatar
Re: Tire size?
At minimun you can mount a 315 on a 10 inch rim. I wouldnt try a 9.5 since the sidewalls are so thin. The tire will just roll under and wont seal the beads correctly.
Old Dec 24, 2004 | 02:39 PM
fesgali's Avatar
Re: Tire size?
I knew a guy that bought a WS6 that the previous owner put 315s on the rear.
Old Dec 24, 2004 | 03:13 PM
NVRLATE's Avatar
Re: Tire size?
I'm running 315's but I have 11" rims. They fit my car but I'm using a 1" billet spacer and had to massage the wheelhouse for additional clearance. I did not have to roll the lip of my quarter panel. I've been running them trouble free for the last two years.
Old Dec 24, 2004 | 03:15 PM
Re: Tire size?
You must have the ZR1 offest of 36mm. I have the grandsport offset of 50mm and they fit fine. A little beating of the wheel wells, and removing the bump stop but the rims fit.
Old Dec 24, 2004 | 03:34 PM
FastZ8's Avatar
Re: Tire size?
so does anyone know if it possible to run a 315 on a 9.5" rim?
Old Dec 24, 2004 | 03:57 PM
hot94z's Avatar
Re: Tire size?
i have mounted 315s on 9.5 wheels they fit but it pulls the sidewalls in a long ways they didnt rub the wheel wells you have to find a shop that will inflate them to about 80psi to seat them it is not easy to get them on the rims a good shop can do it
Old Dec 24, 2004 | 10:14 PM
FastZ8's Avatar
Re: Tire size?
did you have ny rubbing issues and what kind of wheels where you running
Old Dec 25, 2004 | 10:30 AM
95GRNZ's Avatar
Re: Tire size?
I would definetely suggest not doing it. Get a pair of 17x11's and you don't have to worry about anything.
TS
Old Dec 25, 2004 | 11:08 AM
Zack's Avatar
Re: Tire size?
just use a 275, or get the right size wheel. you lose the benifits of the extra width because the sidewall will bulge so much. friend had this with his stang, said he didnt like the way it handled, so he upgraded wheel width from the stock 8 inch wheels
Old Dec 25, 2004 | 06:00 PM
FastZ8's Avatar
Re: Tire size?
do they make any 17x11 that would match a silver painted Zr1
Old Dec 25, 2004 | 10:02 PM
Re: Tire size?
Do you mean chrome, or like hte brushed aluminum? If you are talking about painted silver like the WS6 wheels then no, not that i hacve seen
Old Dec 25, 2004 | 10:11 PM
Re: Tire size?
AFS sells 17x11 ZR1 "replicas" in 1) black powder coat, 2) silver powder coat, 3) polished aluminum, 4) polished aluminum with clear coat, or 5) chrome plated.
http://www.afswheels.com/v2/ecommerce/shopexd.asp?id=22
