tire size
Old Apr 19, 2004 | 11:53 AM
roxzee's Avatar
tire size
Hey everybody! I just purchased 17 inch rims in the front and 18 inch rims in the rear. I was going with 275/40/17 in the front and 295/35/18 in the rear. Are 295's to big in the rear and will there be rubbing problems? I also lowered the car about 1.5 to 1.75 inches. Hoping for some suggestions, thanks!
Old Apr 19, 2004 | 01:04 PM
Whether anything rubs or doesn't rub depends on the wheel width and the wheel offset/backspace. You need to provide the width and offset.
In general, most manufacturers recommend a 10" width for a 295/35-18.
Old Apr 19, 2004 | 03:00 PM
IrocManiac's Avatar
What's the width of your wheels?
Old Apr 19, 2004 | 10:38 PM
roxzee's Avatar
I purchased C5 corvette wheels. They are 17x8.5 in the front 56mm is the offset and 18x9.5 in the rear 54mm is the offset. I'm hoping to fit 295's in the rear, and 275's in the front, any suggestions? Will 295's rub with no modifications?
Old Apr 19, 2004 | 11:28 PM
IrocManiac's Avatar
Those sizes should work, I would not go bigger then 275 in the front on an 8.5 inch rim but you could...as for the back, I would not go smaller then 275 on a 9.5...I'd try to go 295...the 275's shouldn't rub, thats what I'm running on all fours on mine, the 295's I don't think you'll have issues with either.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
blac94Z
Mar 6, 2015 07:55 AM
cristian1311
Mar 4, 2015 04:45 PM
