Tire help
Old Dec 7, 2005 | 08:18 AM
Grims's Avatar
Tire help
I currently have kumho ecsta mx 275/45 on a 18X9.5 wheel in the rear. I have gone through two sets in 8 months...I simply can no longer afford this at upper 200s per tire. What can you guys recommend to me that hooks good but has a decent life span?
Old Dec 7, 2005 | 09:05 AM
Re: Tire help
Why are you using a 275/45-18? That's a 27.7" diameter tire. Maybe its wearing out by rubbing on the wheel wells
Do you possibly mean you are running a 275/40 or 275/35-18?
How many miles before they wear out? What wears out.... full tread surfaces or only the edges, or only the center of the tread? All 4 tires, or the fronts or the backs? Are you rotating the tires?
The survey data at Tire Rack indicates that the best tread wear results for tires in this category are the Goodyear Eagle F1 GS-D3.
Old Dec 7, 2005 | 09:24 AM
Grims's Avatar
Re: Tire help
Sorry my bad, 275/40 tires
The entire tire is being worn down, and they last about 7 thousand miles at the most, and only the rear tyires are beign worn. I have the Kumho 712s in the front and they still look new after 8 months.
The goodyear tire looks good, but the tread wear isbn't that much higher. How much longer could I expect it to last?
Old Dec 7, 2005 | 01:36 PM
Re: Tire help
Have you tried rotating them? That would double the life of a set of 4. I honestly don't know about the tread life on the Goodyears. Its just the highest rates tire for tread wear in the survey. But none of them seem to have much to offer in the way of tread life. That's the trade-off, generally, on a sticky tire.
http://www.tirerack.com/tires/survey...ay.jsp?type=MP
Old Dec 7, 2005 | 02:59 PM
Grims's Avatar
Re: Tire help
I can't rotate them, i have 712s in the front and the ecstas in the rear.
Old Dec 7, 2005 | 09:28 PM
Zack's Avatar
Re: Tire help
if they are the same size, you CAN and SHOULD rotate every 5-6k miles...what do the model differences matter?
Old Dec 7, 2005 | 09:37 PM
Grims's Avatar
Re: Tire help
front tires are for handling in wet weather, not to mention their 17"
Old Dec 8, 2005 | 07:47 AM
Re: Tire help
Might have been a good idea to include that info in the initial post, so we didn't waste our time telling you to rotate them.
Old Dec 8, 2005 | 09:13 AM
Grims's Avatar
Re: Tire help
Well i figured sense I mentioned I had 712s upfront which would do horrible as rear tires, and would be pointless to put good sticky tires in the front....that you guys would not waste your time anyway.
Old Dec 8, 2005 | 08:54 PM
Zack's Avatar
Re: Tire help
we arent the ones that decided to purchase **** tires to begin with...to get longer life, rotate regardless, or dont skimp on tires
Old Dec 8, 2005 | 08:58 PM
Grims's Avatar
Re: Tire help
I have C5 rims, fronts are 17s rears are 18s, I did not buy **** tires....they are around 275 a piece and I did not skimp on anything.
I really don't know of any performance tire combo that you could rotate tires with. Rear tires need to be soft to hook well, front tires can be harder, and are meant for handling, channeling water, dealing with ice ect. It really wouldn't make sense to buy performance all summer tires for the front with a 220 tread
Thanks for posting, but your comment did not in anyway help me decide on my next tire purchase...so it was useless.
Old Dec 8, 2005 | 09:02 PM
Zack's Avatar
Re: Tire help
k, here, you want longer life out of the tires, lose the staggard setup so you can rotate. and you yourself dont have confidence in your tires, so id say they are **** tires
youre in the wrong car if you want long lasting tires
even with rotatable tires, be lucky to get 20-30k out of high performance zrated rubber
Old Dec 8, 2005 | 09:07 PM
Grims's Avatar
Re: Tire help
I said I was getting 8 thousand miles to a tire...I have no problemw ith buying new tires everyonce in a while...but that's just crazy.
I am not going to change to a setup I can rotate because I would rather have very specfic types of tires in the front and back.
Thanks again for pointing it out that I should...but I would rather get a tire in the back that is meant to be a rear driven tire.
Old Dec 9, 2005 | 02:12 PM
"White Knight"'s Avatar
Re: Tire help
I got 8,000 on my nittos A little worn, but still there doing their thing.
You can't find a tire that lets you hook up and go 20-30,000miles, they don't exist otherwise we'd all be using them. Run a harder tire and spin the tires if you want 30,000 miles.
Old Dec 9, 2005 | 03:49 PM
Greed4Speed's Avatar
Re: Tire help
Maybe someone needs to adjust their driving style....
I have BFG KD in the rear with at least 8,000 miles and they're still looking new. This is on a daily driven car too.
I agree w/Zack, the 712's are POO! I have them up front and they suck hairy ones.
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Jul 4, 2015 03:06 PM
