Street Tires PSI at the Drag Strip
Old Apr 6, 2007 | 09:53 AM
MysticTeal95Z28's Avatar
We're going to the drag strip next Friday, what are you guys running for tire pressure on 245/50-16s? The tires are Kumho Ecsta ASX's if that matters. On normal street driving I am running 35 PSI, as indicated on the door. Should I drop the rear down to 30 PSI?
My brother has a '95 Z28 with 275/40-17s on it, what pressure should he be running? They are BF Goodrich KDWS of some sort.
Old Apr 6, 2007 | 10:51 AM
Z-RATED94's Avatar
Believe it or not (your choice) start out a little higher than you normally run on the street. Then work your way down and see if it helps or hurts.
Old Apr 8, 2007 | 06:07 PM
slomarao's Avatar
I wouldn't go under 26-27psi. A normal street tire has a stiff or semi stiff sidewall for handeling purposes. The sidewall is not going to 'wrinkle" like a dr or slick. Start at 35 and go down, avoid the waterbox and do a quick "clean the tires burnout". A street tire isn't going to benefit from a long burnout.
Old Apr 8, 2007 | 08:48 PM
Capn Pete's Avatar
I've cut 60' times as good as 1.92 with street tires pumped to ~35-36 psi, and as bad as ~2.3's with the tires deflated to ~25 psi .
I'm not sure if the 17's take about the same pressure or not though? (probably? )
Old Apr 11, 2007 | 12:10 PM
00ls100's Avatar
street tires suck. I started mine at 30 and by the end of the day I had the psi at 20 they were doing really good at 20 but I was killing my tires.
drag radials
Old Apr 14, 2007 | 11:56 PM
GETGONE's Avatar
It really depends on the tire. I had played with the pressure on my stock Goodyears and it didn't seem to matter what I did. My best time was at the street pressure(32psi). I put my Toyos on after burning off the Goodyears and my best time was actually dropping the pressure to 20psi and doing a pretty long burnout. Rubber compounds vary between tires so it's a matter of figuring out what works best for your car.
Old Apr 15, 2007 | 08:35 AM
lethal93ta's Avatar
I normally had mine at 24 I was getting 1.9 60s on BFG 245 45 17 comp TAs
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Ken Cemo
Jan 27, 2015 08:45 AM
