Stock to 245/45 tire: Drawbacks?
Old Apr 29, 2004 | 02:20 PM
96LT1Fan's Avatar
Would like to get some Toyo T1-S tires, it appears as if they only come in 245/45. I'm still running with my salad shooters. I guess this might be more appropriate in the wheels/tires sections. But I wanted to a little more tech feedback, for example, how would this affect my speedo calibrations?
Old Apr 29, 2004 | 02:35 PM
Cmr0z28's Avatar
They're going to be a little smaller in height and width, may not wear correctly, and your speedometer might be a little off.
Old Apr 29, 2004 | 02:56 PM
GreenDemon's Avatar
Your speedo will read a little higher than the actual speed.
Ride quality may be reduced slightly, however steering feel and response should be slightly improved. Shouldn't cause any major problems though since there's only a minor difference.
Old Apr 29, 2004 | 03:08 PM
stereomandan's Avatar
Should help with steering response. Where your old tires the 235 or 245 series?
You speedo will read slightly faster than your actual speed. I know www.tirerack.com has tire diameter specs for all the tires they sell. Find the size you have now, and divide it by the new tire diameter and that is the multiplication factor of how much faster your speedo will read.
Example: Old tire 25.4" diameter, new tire 25.0" diameter
25.4/25.0 = 1.016
So at 70 mph you are actually going 70/1.016 = 68.9 mph
If they were already 245's before, you will see very little difference, assuming that this tire is similar to your old one.
I noticed a big difference going from the 235 size to the 245/50-16.
Dan
Old Apr 29, 2004 | 06:06 PM
96LT1Fan's Avatar
I'm currently using 245/50s. So, I don't think there will be much of a difference. I shouldn't lose any tire width going from a 245/50 to a 245/45, just a tiny bit of sidewall height. Does anyone think that there will be a noticeable difference in the look of the car. Theoretically... It should lower the car just a fraction as well.
Old Apr 29, 2004 | 09:19 PM
O-taka's Avatar
all those 94s with the 115mph speedo are in the same boat. they came with 235/55/16s i think and i ran 245 50 16s for like 4-5 years before figuring out my speedo was maybe 5-10% fast, and my odo was raping me by the same amount
brian at pcmforless.com corrected that
Old Apr 29, 2004 | 09:48 PM
GreenDemon's Avatar
lol, you just gave me a good idea for odometer fraud.
Old Apr 30, 2004 | 07:36 AM
A 245/45-16 is just about a full 1" smaller in diameter than the stock 245/50-16. Consequences:
Ride height will drop 1/2"
Gap between tire and fender will increase by 1/2"
Speedo will read about 4% higher than you are actually going, or 62.4mph at a true 60mph
Odometer will show 1,040 miles driven, when you actually went 1,000 miles
The last two problems can be cured by a PCM reprogram.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
