rotating tires....question
Old Sep 4, 2006 | 07:08 PM
1slowta's Avatar
Ok this may sound like a really dumb question but when you rotate your tires do you just move the fronts to the back and vice versa? is that all or is there a certain order?
Old Sep 4, 2006 | 07:11 PM
skifast87's Avatar
Re: rotating tires....question
I am pretty srue depending on your tires you criss cross them. front right goes back left. front left goes back right and vice versa
Old Sep 4, 2006 | 07:12 PM
95LT1conv's Avatar
usually you ptu right rear on left front and left rear to right front and front tires go straight back. If you have directional tires, just go front to back back to front
Old Sep 5, 2006 | 01:22 PM
Bayer-Z28's Avatar
You can cross rotate, but I was told when I worked at the Chevy dealer that they didn't want me cross rotoating radials..
Look to see if you have directional tires. If you do just switch the fronts and backs. Keep them on the same side.
Old Sep 5, 2006 | 10:32 PM
Zack's Avatar
you can rotate radials any which way you want..as long as they arent directional
at work we bring the fronts straight back and cross the rears to the front
Old Sep 6, 2006 | 09:55 AM
Need4Camaro's Avatar
I work for Pepboys and I was "TOLD" that on todays tires, Cross rotating will not yield any better results than Front to Back and Back to Front... They don't even allow us to perform cross rotation...
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
cmsmith
Aug 27, 2015 06:37 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Redbird
East South Central
Dec 14, 2002 09:58 AM
