rim and tire fitment question
i just ordered a set (4) of chrome 18x9.5 zo6 rims with a 57mm offset. my 95 z28 has been droped about 1.75 inches. would i still be safe to run 275-40-18 tires or should i go with 275-35-18? and could i go with even a 285 or so on a 9.5 with the drop? thanks for the help in advance
After going to the trouble of lowering the car 1.75", why would you want to raise it back up 1/2" farther off the ground (added sidewall, "40" compared to "35") with the 40-series tires?
because i am now putting on the wings west body kit, and i think im going to be around 4 inches from the ground with it. i think every bit will count. and the other reason is for ride comfort. i little more tire will be a smoother ride. but if it dont fit, then it dont fit.
i found this site, i think is pretty good. it says that the stock tire size is 26.18. then if i went with the 40 it is 26.66. and the 35 it is 25.58. i guess the best way is to take a tape measure to it tomorrow.
http://www.sstire.com/tireheights.html
The base V8 cars got 235/55-16's (26.18"). But if your car left the factory with the Z-rated tire options, which many 4th Gens did, it had 245/50-16's (25.65"). The WS6 and SS's came with 275/40-17's (25.66")
i didnt look on the door, i just looked at the tires that are on there now (235/55-16). the 40 tires will work on there. its only about a 1/4 inch all the way around more then stock.(about a 1/2 total.) i just think the 35s would look better, but a little rougher ride. i would like to a least make it over a speed bump. i will probably go with the 35s and use spacers if i need them. thanks a lot
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Hurin
Dec 13, 2014 07:38 PM
