rim size for my camaro
Old Dec 3, 2007 | 02:10 PM
Bluovlh8er's Avatar
torq thust 2's with this size..... will it fit a 95 camaro???
Rim Diameter (in): 17 in.
Rim Width (in): 9.50 in.
Backspacing (in): 6.500 in.
Offset (mm): +32.00mm
Old Dec 4, 2007 | 01:19 PM
n2ceptor's Avatar
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
From AMR site:
Product Number: 50579563
Product Description: Fully polished
Backside Spacing (in/mm): 7/178
Offset: 45.72mm
http://www.americanracing.com/appguide/index.asp
Old Dec 4, 2007 | 05:47 PM
There's always the FAQ stickied at the top of the "Wheels and Tires" topic listing. If you had looked, you would have found this:
https://www.camaroz28.com/forums/sho...4&postcount=17
9.5" Width:
Tire edge outside fender = +32mm
Tire edge slightly inside fender = +49mm
Tire edge matches stock SS/WS6 wheel = +57mm
The most trouble free setup is an offset in the range of 45-56mm. The tires will not rub on anything, except possibly a car that has been lowered 2", when the steering is near "full lock" or if you hit a bump and compress the suspension further.
An offset of 35mm will put the outer edge of the tire barely under the outer edge of the fender.
HectorM52
Jul 30, 2017 11:46 AM
Kato
Jan 26, 2015 09:21 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
siguy
Nov 27, 2014 10:07 AM
