Which Rim Fits?
Old May 12, 2004 | 10:54 PM
CAMZ97's Avatar
Question Which Rim Fits?
Hey whats up, I want to put some slicks on the car for the next time at the track. I want to put a 15" rim with a 28x10 slick, I think thats a good combo for my setup. My problem is I tried about 3 15" rims and all 3 hit my calipers. Which 15" rim fits over those calipers without shaving the calipers. If there is no such rim any opinion on a 16" rim and tire combo would be appreciated.
Old May 13, 2004 | 12:03 AM
badblackta's Avatar
centerline telstar will clear the caliper. I didnt grind the caliper or anything. I just ordered them from jegs, had the slicks mounted, and went. It is a tight fit, but it clears just fine. THe backspacing looks perfect IMO.
Old May 13, 2004 | 12:53 PM
No big deal to grind the fins off the calipers.... its just the part that wraps around the "corner" of the caliper, not the whole thing. Weld Pro-Star or Draglite 15x10 with 7.5" backspace.
Bogart makes a 4th Gen specific wheel in 15x9.75" that clears the calipers. It has the correct offset to keep the tire inside the fender. The Telstars tend to stick out a bit for my taste.
Old May 13, 2004 | 02:16 PM
badblackta's Avatar
My 15X8 telstars dont stick out from the fender. Maybe you used a 15x10 or something?
Old May 13, 2004 | 02:47 PM
CAMZ97's Avatar
yeah i dont want em sticking out of the quarter. How about centerline convo pro, I can get my hands on a set at a good price I believe the guy was using them on a 2000 TA
Old May 13, 2004 | 02:55 PM
They do not make the Convo-Pro in the correct backspace, and when I asked them for a custom set a few years ago, they were not interested. If I had it to do over again, I would have ordered my Strange 12-bolt in the 3" narrower "3rd Gen" version, reducing the backspace requirements by 1.5"
Old May 13, 2004 | 10:03 PM
CAMZ97's Avatar
yeah i think think the convo pro comes with a 5" backspacing, I believe it will be enough to tuck under the quarter but I am not sure
Old May 13, 2004 | 10:28 PM
badblackta's Avatar
the convo pro is a 15x8.5. With the 5 inch backspacing it might stick out a little. The telstar, 15x8 with 5 inch backspacing will tuck under the fender no problem.
Old May 14, 2004 | 07:13 AM
CAMZ97's Avatar
i heard the same about the telstar the other difference is the telstar is much more heavy
Old May 14, 2004 | 10:29 AM
I think to some extent, what "tucks under the fender" is a function of what width tire you put on the wheel. The outer edge of a 15x8 wheel, with 5.5" BS, will end up in exactly the same place as the wheel in this picture (15x10 7.5" BS):
http://cjcfo.fbody.com/members/injun.../DCP03453a.jpg
If you drop the backspace to 5.0", the tire has to move 1/2" further out. Whether this is acceptable to you sort of comes down to a personal preference.... there is no hard and fast answer. That's why I qualified my original comment with "...stick out a bit for my taste."
Old May 14, 2004 | 01:26 PM
CAMZ97's Avatar
to me thats a nice look in that pic, but with a 1/2" less backspacing(5") will it rub the quarter?
Old May 14, 2004 | 04:04 PM
Reducing the backspace moves the tire out, toward the outer edge of the fender. It will only be a problem with clearance to the edge of the wheel opening if you are running a 28" tire. My 28" QTP's required moving the axle back about 1/4" with an adjustable LCA. The 28" ET Drags in that picture required major cutting to the leading edge of the rubber bumper cover.
28x11.5-15 Hoosier QTP
28x10.5-15W ET Drag - with only 1/2" off the bumper cover. I ended up with 1.5" cut off.
Old May 14, 2004 | 08:27 PM
CAMZ97's Avatar
Well the guy that i bought the wheels from dropped them off. They are 15x8 1/2 centerline convo pro's with a 5" backspacing. The rubber on the wheels are ET streets 26x11.5 with only 3 passes on them, Both rims and tires are mint. I paid $275.00 for the rear setup I passed on the matching front wheels, He wanted an extra $200.00. I figured I didnt need them since I think I will be running in the high 12.s for now,until the heads get done in january 2005. He has a 2002 TA which he told me that when he staged with this rim-tire setup he dumped the clutch with gas pedal smashed and the rev limiter screaming and a 125 nos shot these tires hooked up without spinning. I think I believe him I just dont know if the ET streets can really do that
Old May 14, 2004 | 08:30 PM
CAMZ97's Avatar
By the way Thanks to Injuneer and badblackta
for your help and interest in this
Old May 15, 2004 | 08:30 PM
CAMZ97's Avatar
Well I tried the wheels on today and let me say I HATED THEM. They stick out way to far for me, Can anyone sudjest a rim that will not stick out
