Rear C6 Wheels Issue.
Old Feb 16, 2006 | 10:16 PM
DontMixWithRice's Avatar
I can't fit the rear c6 wheels on my 95.
Where can I buy spacers online? Also, Ill need longer wheel studs for the back...any part number for that?
thanks.
Old Feb 17, 2006 | 08:10 AM
Re: Rear C6 Wheels Issue.
c'mon guys...I have bad *** C6 Wheels in my room...adn they should be on my whip!
Old Feb 17, 2006 | 09:24 AM
What size/offset C6 wheels are you trying to put on the car? Why don't they fit?
-hub hole in wheel will not fit over hub on axle?
-offset of wheels too big and they hit the jounce bumper bracket, or the inner fender liners?
Hard to answer the questions without more details.
Old Feb 17, 2006 | 09:52 AM
sorry. they are rubbing the inside wheel well. I need rear spacers and longer wheel studs...
Old Feb 17, 2006 | 09:53 AM
Also, the rims are off a 2006 C6...
The rims' bolt pattern fit perfectly with the studs, but they are too close to the inside wheel well.
Old Feb 17, 2006 | 10:36 AM
96m6lt1's Avatar
i had the same problems on my 96 with the vette wagon wheel(97-99)the rears require the stud length of a vette stud,as far as the backspacing being too close to the inner well you will need to massage(beat the hell out of it)my clearence issue was the front lower portion of the inner well closest to the lower control arm,10lb sledge worked fine.
Old Feb 17, 2006 | 10:46 AM
Can't help you unless you know the offset of the wheel, the thickness of the spacer.
Old Feb 18, 2006 | 05:50 PM
slayer6x6's Avatar
Are they the repro 19s? I had to remove my bumpstops and airhammer the inner fender to get my 19s to fit w/o spacers
If you have 18s you will be in better shape.
If you have the OEM wheels you need something along the lines of these.
http://cgi.ebay.com/ebaymotors/WHEEL...spagenameZWDVW
Old Feb 20, 2006 | 01:29 PM
yup...they are oems...and thats exactly what I did....except I played it safe and bought 1.25....
thanks for your help...
carguy0119
Apr 11, 2016 11:11 PM
dpw21562
Jan 23, 2015 04:58 PM
Moshbmx1
Jan 20, 2015 03:27 PM
Dimoncutr
Aug 18, 2002 09:39 PM
