Quick Wheel Question
Would these fit on a '96 Z
Foose Speedster5 18x8.5
http://www.superbuytire.com/images/w...Speedster5.JPG
Tire recomendation is: 245/40/18
What do you guys think?
Re: Quick Wheel Question
Whether they will "fit" depends on the bolt circle (you need 5x4.75"/120.65mm) and the offset (you need something in the range of 35-50mm).
Tires are the correct diameter to replace the stockers, if your car came with the 245/50-16 tires. Unfortunately, they are no wider.
Hey, thanks for the response.well, you know they do come in 9 and 10 inch withs.......................
Just that it is in 20 to 26 inches in dia.
You think it's a good deal, $2g's, mounted, balanced and installed?
ChrisFrez
Nov 30, 2014 08:41 AM
redzed
Sep 4, 2002 06:22 PM
