Question on wheel studs and spacers
Old Mar 16, 2006 | 09:50 AM
asudecat's Avatar
If I wanna run about a 1/2" spacer in the rear, will I need longer wheel studs?
thanks
Old Mar 17, 2006 | 07:40 AM
asudecat's Avatar
Re: Question on wheel studs and spacers
surely someone knows this
if so where do I get the wheels studs and how long?
thanks again
Old Mar 17, 2006 | 12:18 PM
You can check it yourself. Unscrew a lug nut until it is 1/2" from the seat. If the stud threads still extend 12mm into the threaded portion of the lug nut, you are OK. If they don't, you need new studs.
I think the reason no one knows is because the use of "spacers" seems to be limited to the thin ones you need to use Weld Pro-Stars.... 5/16". I don't think its a good idea to use a wide slip-on spacer. It stresses the studs. You get a billet spacer that bolts to you stock studs, and has a second set of studs to bolt your wheels to. Not sure if they make them in 1/2", but this source could tell you:
http://www.skulte.com/
Airplanedoc
Feb 1, 2015 07:14 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Catmaigne
Dec 25, 2014 12:16 PM
ChrisFrez
Nov 30, 2014 08:41 AM
Jul 4, 2005 05:00 PM
