New Rims Help!
Old Jan 16, 2006 | 12:19 PM
Z28 97's Avatar
New Rims Help!
I have my mind pretty set on this auction on ebay...if someone can help me out on what you think...Thanks
http://cgi.ebay.com/ebaymotors/18-CO...29327600QQrdZ1
Old Jan 16, 2006 | 04:07 PM
Re: New Rims Help!
The 275/40-18 tires are correct for the Corvette, not for the 4th Gen F-Body. They are 1" larger in diameter than your stock tires, assuming you started with the Z-rated 245/50-16's. They will raise your car 1/2" farther off the ground, and cause the speedo to read 4% lower than actual speed, unless you have the tire size corrected in the PCM.
The offset of the wheels is shown as 50mm, which is OK for a 9.5" wide wheel on a 4th Gen.
A 275/35-18 would be a closer match, being about 1/4% smaller than the stock 245/50-16's.
If your car did not have the Z-rated tire option (RPO QLC), the difference will not be as much. The 275/40-18 is only about 1/2" larger in diameter than the 235/55-16's that came on the base V8 cars.
Old Jan 16, 2006 | 10:47 PM
Z28 97's Avatar
Re: New Rims Help!
What about lowering the car?
Old Jan 17, 2006 | 07:26 AM
Re: New Rims Help!
Lowering the car will reduce or eliminate the 1/2" gain from the oversize tires. That will also force the tires farther up into the wheel wells when the suspension compresses. At stock ride height, they are already 1/2" closer to the edges of the fender lip. Lower it, and the gap drops even more.
Probably no big deal one way or the other, as long as you are aware of the potential issues with the oversize tires.
There was a thread here a month or so from a guy who had a problem with 40-series tires ripping the fasteners for his ground effects kit off.
Old Jan 17, 2006 | 10:54 PM
Z28 97's Avatar
Re: New Rims Help!
so what u think i should do? i dont have groud effects on my car...i love the rims n thats the only sort of good deal i can find...
Old Jan 17, 2006 | 10:58 PM
Zack's Avatar
Re: New Rims Help!
you can easily find a better deal
(lots of)falkens are crap anyways
Old Jan 18, 2006 | 11:43 AM
Z28 97's Avatar
Re: New Rims Help!
Where can i find the c6 Z06 rims in chrome 18x9.5...i would like to get a package deal so its cheaper....If any one can help me that would be great...Thanks
Old Jan 18, 2006 | 01:01 PM
ulakovic22's Avatar
Re: New Rims Help!
http://www.lakeshorewheelandtire.com...o-choose.shtml
This place is ok. Check sig for pics of how they look on my car. BTW, I'm running 275/35/18's
Check out Discount Tire as well.
Old Jan 18, 2006 | 04:21 PM
Z28 97's Avatar
Re: New Rims Help!
those are nice but there more expensive
Anything cheaper?
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
