Need some suggestions on tire sizes for ¼ mile
Old Dec 28, 2011 | 08:29 AM
30th_ANNIV_Z28's Avatar
Question Need some suggestions on tire sizes for ¼ mile
I plan on buying black polished Torq Thrust M's when I get back from Afghanistan. I was thinking I want 17x 9 all around but I'm not sure what the advantage is to having larger wheels on the back. These rims are going to be for the track only and I have some torq thrust 2's I have for the road that are 17x9 with 235/45ZR17. What wheel sizes and tire sizes would you guys recommend.
Sorry if this has been posted before I couldn’t find any other threads on specific tire sizes
thanks
Old Dec 28, 2011 | 09:06 AM
Re: Need some suggestions on tire sizes for ¼ mile
If you are buying wheels for the drag strip only, buy light weight 15" drag wheels (e.g.- Weld Pro-Stars or Draglites). You don't want to use heavy 17" street wheels. There is no advantage to a large diameter wheel for the track. More of a disadvantage, since you have less sidewall to work with.
Look at the "sticky" for "Drag Wheels".
https://www.camaroz28.com/forums/whe...wheels-576054/
For what you list as mods, 26" DOT slicks or Drag Radials will be fine.
PS: 235/45-17 isn't the best choice for a street tire. Those are about 1/2" smaller diameter than stock, and sort of narrow for a 9" wide wheel.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
Ken Cemo
Jan 27, 2015 08:45 AM
