My Camaro rims on an Impala?
Old Jun 10, 2015 | 03:38 PM
Javi Fierros's Avatar
I have 20 " IROC rims that I'm selling. A buddy of mine wants them for his 2008 impala originally j thought it was the same bolt pattern but Camaros are 5X120 and I believe his was 5x115- so this would be a problem right?
Old Jun 11, 2015 | 07:41 AM
Re: My Camaro rims on an Impala?
Obviously you can't directly bolt a wheel with a 4.75" (120.65 mm) bolt circle on a hub with a 115 mm (4.53") bolt circle.
The possible solution would be an adapter that bolts to the 115 mm bolt circle hub, and provides a new set of 4.75" bolt circle studs.
Whether this will work will depend on the offset of your wheels vs. the required offset of the Impala wheels (which I have no idea about). This would have to provide sufficient tolerance to allow the insertion of the adapter, which I would assume would to equivalent to adding a spacer of at least 0.75" thickness.
Then you would have to check for the availability of the specific adapter.
HectorM52
Jul 30, 2017 11:46 AM
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
