i need help with size and brand on 97 z28
Old Feb 21, 2011 | 02:52 PM
bs-97z28-6sp's Avatar
i have my 97 z28 with the stock 16" rims. what is the best tire size, combo or tire for this car? i woul like a wide tire that doesnt rub because i do alot of street racing but also daily driving. any advice would be appreciated!
Old Feb 21, 2011 | 06:06 PM
Re: i need help with size and brand on 97 z28
There's really not much available in high performance tires for the stock 16x8" wheels. Did your car leave the factory with the "base" V8 model tires (235/55-16, 26.1") or the optional Z-rated tires (245/50-16, 25.7")? That will determine the size required to avoid reprogramming the PCM for the relatively minor speedo error from not matching the stock diameter. There should be a label on your driver's side door or on the dor jamb showing the stock tire size.
You only real choices in a 16" tire would be a 245/50-16 or a 255/50-16 (26.0").
The stickiest tires would be drag radials from BFG, M/T or Nitto. But they aren't very good in the rain. The Nitto's are probably the best for street use, but still not as sticky in the rain as a non-drag radial.
Go to Tire Rack, and put in the tire size. It will give you all the choices they offer (they do not sell Nitto, and there aren't many manufacturers at all making the 255/50-16 size any more). For a tire that interests you, click on the "Survey" link. When that page appears, look for the link to "See a full list of survey results for high performance (or whatever) tires". That will give you relative ratings for things like dry traction, wet traction, cornering braking, noise, fuel economy, snow performance, etc.
Old Mar 20, 2011 | 09:29 PM
thanks, i was looking at the bridgestone gforce 255/50r16. it came with the 245/5016. i just dont want anything to rub ya know.
HectorM52
Jul 30, 2017 11:46 AM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
Dec 5, 2014 11:42 AM
