i know, i know...another will it fit question...
19x8.5 inch 19x9.5 inch, 5x120mm 35mm/40mm
I've already searched through the sticky above and I'm horrible with math...they're BMW rims so I know the bolt pattern issue, but would the above rims fit work with that backspace, etc? Would I run into issues of rubbing, etc? TIA!
8.5
Tire edge outside fender = +19mm
Tire edge slightly inside fender = +35mm
Tire edge matches stock SS/WS6 wheel = +44mm
Tire edge matches stock wheel = +60mm (may have backspace problem with front steering knuckle.
9.5
Tire edge outside fender = +32mm
Tire edge slightly inside fender = +49mm
Tire edge matches stock SS/WS6 wheel = +57mm
The most trouble free setup is an offset in the range of 45-56mm.
Again, TIA!
I know that the right bolt pattern will not give me failure issues, and that maybe a bimmer wheel will, breaking studs I'm not into. I don't like maybe's on something that is as important as my wheels fitting and staying on the car, just my feelings on this.
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
