How much are these worth? **PICS**
Old Apr 16, 2008 | 12:32 PM
camarostripe96's Avatar
From: Academy,tx (Home to Temple/Academy Drag Strip)
how much are these worth and will they fit on my 96 trans am. they are
15x7 summit weld wheels Has 5x4.75 bolt pattern, the back spacing is 3 1/2 to 4 ..here is the link
http://www.ls1tech.com/forums/showthread.php?t=903561
would they work on my trans am and how much are they worth
Old Apr 16, 2008 | 12:49 PM
I see you posted this on at least two different sites in the engine tech forum. Why not delete this and repost to save a moderator the trouble of moving it?
Old Apr 16, 2008 | 12:50 PM
Wrong forum... LT1/LT4 Engine Tech is not for questions about wheels. Moving to "Wheels and Tires".
Old Apr 16, 2008 | 12:58 PM
ok wasnt sure sorry
Old Apr 16, 2008 | 01:05 PM
so would these fit?
Old Apr 16, 2008 | 06:10 PM
Are you looking to put these on the front, the rear, or both?
They would need 5/16" spacer in the front, and grinding of the brake caliper cooling fins in the rear. See the Wheels and Tires FAQ, for details of fitting Weld wheels (not sure what "Summit Weld" wheels are).
A 3.5" backspace would put them just outside the fender line. A 15x8" works best with a 5.5" backspace, so a 15x7" would work best with a 4.5" backspace. When you put a skinny wheel/tire like that so close to the outside of the fender, it doesn't look too good, sort of like "outriggers".
Devinfoote87
Feb 12, 2016 03:21 PM
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
whitehooptie
Aug 17, 2015 08:35 AM
