how to measure a wheel?
Old Apr 28, 2004 | 01:27 PM
slp223's Avatar
i bought a used wheel and want to find all the specs on it I know it is 15 inch on the width do you measure form the widest points or on the inside of the lip? how do you find the back spacing.
thank you.
Old Apr 28, 2004 | 04:50 PM
The width is measured inside the side flanges, exactly where the tire beads will sit.
Check this info at Tire Rack:
http://www.tirerack.com/wheels/tech/offset.htm
Backspace is measured by laying a straightedge across the far outside back edge of the wheel, and meauring the distance from the surface that mounts to the hub to the straightedge.
jasonduaine
Jun 4, 2015 09:29 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:33 PM
Jul 4, 2005 05:00 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
