help with finding right size tires, questions
I'm planning on getting some new c6 rims to put on my 96 Z. The fronts would be 17's and the rear 18's....what tires do i need for these rims? and does anyone know if they will fit ok, as in not throwing off speedometer, no rub, stuff like that... I'm hopin you guys can help me out and thanks
Need info on the specific wheels you are buying. You gave us the wheel diameter, but we also need the width and the offset. Appears they are "repro" wheels and not OEM C6 wheels. That's the only way to know what tires are required, and whether they are going to rub.
Also need to know if your Z left the factory with 235/55-16 (26.1") tires or 245/50-16 (25.7").
ChrisFrez
01-11-2015 03:47 PM
Brandon Wittmer
12-20-2014 09:51 PM
Hurin
12-13-2014 07:38 PM
