GTA wheels on a 4th gen
Old Dec 20, 2004 | 02:55 AM
staze's Avatar
My stock wheels are starting to pit and I want to get rid of them. I love the look of the old GTA wheels. What problems would I run into if I mounted them on my 1999 Trans Am? I'm not even sure what size the GTA wheels are. I think they're 16 x 8? Offset... info... suggestions, anyone?
Old Dec 20, 2004 | 08:29 AM
Kataklysm's Avatar
Re: GTA wheels on a 4th gen
I think they should go on there with no problems but I'm not positive. All I know is I put a 4th gen donut on an 88 GTA and it worked fine. Donuts are probly different though.
Old Dec 20, 2004 | 10:56 AM
The bolt circle is the same, but typically the 3rd Gen wheels have about 1.5" more backspace, due to the narrower rear axle assembly. This might not be a problem, since the wheels are only 16x8. They should just barely tuck in under the fenders.... the back will be easier than the front.
Old Mar 20, 2005 | 07:28 PM
lt4 fd's Avatar
What if you got 2 sets of back wheels that way they would tuck in the front a bit better, 20mm better I believe??? I had a set of 3rd gen formula wheels on my car with the 0mm offset and 225's and they barely fit, I mean they were right at the edge of the front fender. I think they would look great as long as you could get 2 sets of rears with the 20mm offset... anyone concur?
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:33 PM
JoshGuitar
Jul 23, 2002 06:20 PM
formula79
23
Jun 20, 2002 01:42 PM
