Which drag tires for my new Sawblades?! ---
I am new to the drag tire game. I just scored a set of vette' c4 sawblade wheels in 17 x 9.5" . I need tires I can drive LEGALLY to the track on the highway about 25 miles.....does that mean I need drag radials? These will only be used at the track ... and to and from the track once a week.
I want the BIGGEST tire I can fit ... right now my rears are the 315/35/17's on zr1's so a tire around that size (diameter) will work best for me (or a little taller but obviously not as wide ) ... THANKS for your time and help
. What size/brand do you recommend?! ---
* EDIT the tires on the wheels right now are 275/40/17's , just an FYI incase you needed to know that *
. What size/brand do you recommend?! ---* EDIT the tires on the wheels right now are 275/40/17's , just an FYI incase you needed to know that *
they make a 275/40/17 mickey thompson et street radial, which would be perfect for you. I personally wouldn't get the 315/35/17 m/t radials.... they won't safely fit on that rim, and you would be running a lot less sidewall..... that and they are on backorder for awhile...
Why does a 315/35-17 have "a lot less sidewall" than a 275/40-17? The both have the same sidewall height. Not that I would put the 315 on a 9.5" wide wheel, but I'm trying to understand what you are saying.
Should I go to a size with a bigger sidewall....I trust you the most out of anyone in the auto world when it comes to opinions , ahaahahh ---
I guess "a lot" was the wrong term to use....
I've read different feedback on different threads from people who have gone from 275/40/17's to 315/35/17's and say it wasn't worth it. They didn't get much more traction and wasn't worth the extra money for tires. Correct me if I'm wrong but I was under the impression that the aspect ratio was how much sidewall the tire had.
and as far as the m/t 275's hooking... I ran those for awhile on my draglites, and I loved them. It was a horribly prepped track, but I could dump the clutch at 3500 rpms and just chirp them... almost 4500 with slipping the clutch. I would imagine they would hook better on a prepped track.
If you do the math:
275/40-17:
(275/25.4) X 0.40 = 4.33" sidewall
315/35-17:
(315/25.4) X 0.35 = 4.34" sidewall
The 315 actually has a SLIGHTLY taller sidewall, not that it is a significant difference.
Good idea....it would suck to have it rain on the way home from the track ( has happened before ) ... and be driving the truck on 4 skiis , lol ---
Just thought of a question....will I have a problem running the MT's on the rear and the BFG's on the front on the SYCLONE?! That may be the setup I go with
Last edited by AlwaysCode390; May 3, 2007 at 01:28 PM. Reason: didnt state "on the syclone" before ---
If it were me..... I would go and buy 4 nitto drag radials and throw them on. They have excellent hook and actually have enough tread to keep you and the car safe in basically all summer conditions.
Brandon
Brandon
