drag radial
Old Feb 14, 2005 | 02:40 PM
EVERESTZ28's Avatar
drag radial
hi:
I'm wondering if someone is using the mickey thomson drag radials, i had tried nitto drag (good and durable for that kind of tire), now i'm using BF goodrich drag radial, no spin with 150 shoot, but i had driven for 3 k and are out of wear, so they handle very good but wear so quickly, now i want to try the Mickey thomson, but i don't know how are they doing
Old Feb 15, 2005 | 02:24 PM
Chris@Tires.com's Avatar
Re: drag radial
From what I've heard the M/T is about twice as soft as the BFG.
Don't give up on the BFG yet, they're the best when they're worn out.
Old Feb 16, 2005 | 10:08 AM
EVERESTZ28's Avatar
Re: drag radial
realy!? coool
Old Feb 16, 2005 | 12:54 PM
EVERESTZ28's Avatar
Re: drag radial
do you have a rule to no make jobs in worn tires?. I install the BF on a tire discount store in El Paso, and on past saturday i went to Fireston store to rotate them, because the inside of the tire are BALD and a little tread on the outside, but they sayed no, "you need a new tire". and reused to make the job. It's normal? If i go to DIscount tire, am i going to have the same answer?
Old Feb 16, 2005 | 12:59 PM
Re: drag radial
Yes sir. It's a liability issue, if the vehicle leaves a shop unsafe and something bad happens, the responsibility falls in their hands. They're not trying to run you off, they're just covering themselves.
RUENUF
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
