corvette wheels
Old Apr 14, 2004 | 05:17 PM
PURPLE 97 Z's Avatar
corvette wheels
hey guys quick ? the late model 5 star vette wheels ( like 99-00 ) do they come in any other sizes then 17x8.5 and 18x9.5. i was looking for like a 18x11/10.5 or 17x11/10.5... i have looked around the web and can not find any thing. any help would be greatly appriciated.
thanks gabe
Old Apr 14, 2004 | 09:55 PM
You might want to post this on the new "Wheel & Tire" forum.
Old Apr 14, 2004 | 10:48 PM
95_LT1_6SPD's Avatar
you can get them in 18x10.5 and 17x9.5
Old Apr 15, 2004 | 02:42 AM
jdhommert's Avatar
Make sure you get the right offset too for Fbodys,and not the Vette offset, so you don't have to run spacers.
If you run spacers that are 1/4" inch or more,its a extremely good idea to upgrade the shorter weaker stock studs to Longer,stronger ARP studs.
That can be a PITA to do them in the back,if you don't have TCS/ASR When a buddy and I did mine, we had to pull the axle's out of the housing,so we could get the stud in,because the studs are so long compared to stock,that you can't even get a good enough angle to get the stud in.
Make sure you use Grade 8 nuts though, but good luck finding those in the same size of the studs
Just a fair warning.
Old Apr 15, 2004 | 02:12 PM
DeezT/A's Avatar
what is the stock offset?
Old Apr 16, 2004 | 08:10 AM
Jay-Roll's Avatar
I think it's 56mm for an F-body but don't quote me on that one.
Old Apr 16, 2004 | 10:00 AM
phrozen's Avatar
offset is also different for 'verts.
Old Apr 16, 2004 | 12:57 PM
That would surprise me. I have compared the fit a set of real Grand Sport offset wheels on a friend's 30th SS convertible, to the fit of a set of replica GS offset wheels on my coupe (17x9.5 56mm F, 17x11 50mm R) and they were essentially identical.
The stock wheels are:
16x8 55mm offset (approx 6-5/8" backspace)
17x9 55mm offset (approx 7-1/8" backspace)
I have successfully mounted 17x9.5's on the front with offsets ranging from 49mm (7-1/8" BS) to 56mm (7-3/8" BS). I think you could go as low as 45mm in the front before the tire gets too close to being outside the edge of the fender, and no more than 56mm, because the inside edge of the wheel is very close to the steering knuckle. With an 18" wheel, you could probably tolerate a little more backspace, since the knuckle is sloping away from the wheel as diameter increases.
In the back, the 17x11's need a 50mm offset (7.93" BS), to keep the tire/wheel completely under the edge of the fender, when viewed straigh down from the top. The 7.93" BS requires hammering on SOME 4th Gens. Anything more than that and you are in big trouble.
Some data from VETTE magazine on the C5 wheels (BS shown is APPROXIMATE conversion from width/offset numbers):
Z06:
-18x10.5 - 58mm (8" BS)
-18x9.5 repro - 61mm (7.60" BS)
-17x9.5 - 54mm (7.33" BS)
-17x8.5 repro - 56mm (6.90" BS)
2001-02:
-18x9.5 - 65mm (7.76" BS)
-17x8.5 GM - 58mm (7.00" BS)
2000:
-18x10.5 repro - 58mm (8" BS)
-18x9.5 - 65mm (7.75" BS)
-17x9.5 repro - 56mm (7.40" BS)
1997-99:
-18x9.5 - 61mm (7.60" BS)
-17x8.5 - 56mm (6.90" BS)
Old May 5, 2004 | 10:18 PM
Kris96WS6's Avatar
corvette magnesium 18x9.5 offset?
Anyone know what the offset is for the Corvette Magnesium 18x9.5 wheel is?
I have 4 and am hoping they will fit on all 4 corners without any trouble. (96 Firebird)
Kris
Old May 9, 2004 | 03:15 PM
Lisa33's Avatar
Think it is 65mm on the 18x9.5
I have them on my car but it is the 17x8.5 in front. No spacers
http://home.koping.net/u3243a/images...s/DSC01569.JPG
Old May 9, 2004 | 10:32 PM
Kris96WS6's Avatar
Thanks for the info and the Pic,
Nice ride, It looks good with those wheels.
Old May 10, 2004 | 12:39 AM
Lisa33's Avatar
1996LT1Z28
Apr 14, 2015 07:15 PM
sloppytot
Feb 25, 2015 08:30 PM
Moshbmx1
Jan 20, 2015 03:27 PM
CaRParts102
Dec 6, 2014 08:45 AM
