Centerline Auto Drags??
Old Jan 5, 2006 | 03:36 PM
SOM 2002 Z28's Avatar
I would like to put 15x5 1/2 and 15x8 1/2 Centerline Auto Drags on my 2002 Z28 (I like the retro look) but don't know if they will fit. I have seen the posts about the Welds having a brake caliper clearance issue and seen pics of cars with both the Centerline TelStars and the Centerline Convo Pros, but don't know if those had issues as well. Anyone ever try these?
Old Jan 5, 2006 | 08:13 PM
ABA383's Avatar
Re: Centerline Auto Drags??
The Telstars and Convo Pros will fit with no grinding at all. I'm assuming that the Autodrags would be the same. You have to find out what the rear spacing is for the rears though...The Convo Pros only come in a 15x8.5 with a 5" backspace and they stick out just a hair too far imho...The Telstars are 15x8 with a 5.5" backspace and they tuck under nicely.
Check out the Drag Racing section under "post your rides" either page 7 or 8 there's a green TA/Formula with what looks like autodrags and they look good...I guess you could ask him...
--Alan
Old Feb 3, 2006 | 11:33 PM
96camaroSS's Avatar
I put 15x10.5's on the back of my car for certain occasions. I don't remember what the backspacing is but I did have to file down the fins on the calipers a bit to make them work. I don't know if they used the same calipers on the LS1 cars for the rear though. I know the fronts are bigger than the LT1 cars. This might cause clearance problems for you that I didn't have.
Aug 24, 2015 06:41 AM
94Form
Jul 17, 2015 10:56 PM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
