Center bore question
Old Jan 28, 2008 | 03:28 PM
kick Z tail out's Avatar
Question Center bore question
This is reference trucks, not the F-Body if it makes any difference...
When looking for wheels, does it hurt if the center bore of the wheel is larger than needed? Is lugcentric a concern?
Old Jan 28, 2008 | 04:02 PM
There are two ways to center the wheel on the hub.....
Lug-centric uses the lugs to center the wheel. Either conical or shank style lugs will accomplish this.
Hub-centric provides a hub hole in the wheel that fits tightly to the axle hub, to center the wheel.
You have to use one of those methods. If you use lug-centric centering, the diameter of the hub hole can be larger than the diameter of the hub. If you use hub-centric centering, the hub hole has to match the hub diameter.
Old Jan 28, 2008 | 06:49 PM
FivePoint7z28's Avatar
For many wheels they also sell Hub Rings for certain wheels combinations on certain vehicles that will make them virtually hub-centric
Old Jan 28, 2008 | 10:21 PM
Zack's Avatar
for the colorado nate? the hubs on those trucks are big and i cant think of any 6 lug wheels with a bore any bigger than that haha
Old Jan 29, 2008 | 05:36 PM
Well, I managed to find a ton of them
But yeah, it's for the Colorado. I'm probably going to go with the AR Bajas just like I had on my K5. Polished 15x8s with -19mm offset.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Feffman
Oct 9, 2015 05:42 AM
Lederman1976
Nov 30, 2014 05:21 AM
