Can you help me identify these wheels??
Old Jul 25, 2010 | 10:27 PM
jmjeeps's Avatar
They came on the z28 i just picked up and im trying to find out what they are, and what theyre worth? Im putting some serious consideration into selling them to buy a kick *** set of nittos and front tires for my track wheels.. Any help would be appreciated!
Old Jul 25, 2010 | 11:07 PM
Looks like a repro ZR1.
What is that weird black molding on the edge of the wheel opening?
Old Jul 25, 2010 | 11:11 PM
jmjeeps's Avatar
****ty stick on molding the previous owner had on it.. Not to worry though, the front end is already swapped.. Check it out! Also, any idea what theyre worth?
Old Jul 26, 2010 | 05:17 AM
Do you know the size of the wheel? Are the fronts and the backs the same?
Old Jul 26, 2010 | 11:09 AM
jmjeeps's Avatar
Ill measure them in a few and check. Theyre 17's but i have to check the width.
Thanks igotyou! lol
Old Jul 26, 2010 | 11:43 AM
Typical sizes are 17x9.5 (front or all around) and 17x11.0 (rear). The front wheel pictured looks a little deeper dish than my 10 year old polished AFS ZR1's. And the edges of the spokes look a bit sharper than imne, so may be a different manufacturer.
The Camaro factory SS wheels have a similar appearance, and SLP sold aftermarket sets. They were only 17x9.0".
This is the AFS 17x11.0. Ignore the oversize lug nuts... I have extra long 1/2"-20 studs for my drag wheels.
Old Jul 26, 2010 | 12:18 PM
jmjeeps's Avatar
Trying to figure out how they are measured? Is it from the back of the weel to the front, or the back to the lip? Here is a pcture of one front, and one back. Excuse the filth.. The car needs a bath!
Old Jul 26, 2010 | 12:37 PM
razor02097's Avatar
diameter, width
back spacing.
Old Jul 26, 2010 | 01:02 PM
jmjeeps's Avatar
Thanks Razor! So that would make those wheels, front and back both 10.5"? That doesnt seem right, they must be 9.5's? Its probably a lot easier to make the measurement with the tire off!
Old Jul 26, 2010 | 03:22 PM
You measure the outside of the wheel - with the tire off makes it easier. If its a 9.5" wide wheel, the actual width will be closer to 10.5". A 9.5" wide wheel has the 9.5" measurement between the bead seats, as shown in the diagram above. The 9.5" wide ZR1's (and that's what yours look like, based on the hubs) are typically 10.4" wide if you lay them flat on the floor. and put a level across the top.
Old Jul 27, 2010 | 07:34 AM
razor02097's Avatar
whats that tire size? Looks like P245/45R17. If that's the case the tire is 9.65" which would likely make the wheel 9.5" wide and 17" diameter.
Just a guess though the only way to really tell is either to find the make and model of the wheel to pull up a spec sheet or to take the tire off and physically measure the wheel.
Old Aug 3, 2010 | 07:02 PM
jmjeeps's Avatar
razor, yeah thats the tire size!! sry, didnt realize the post had a couple replies!!
Old Aug 4, 2010 | 08:48 PM
dpsteele's Avatar
The wheel size (diameter, width, and back spacing) should also be cast on the back of one of the spokes. You might be able to use a mirror and see it without even taking a wheel off the car.
Latronaxe
Jun 10, 2015 02:08 PM
jasonduaine
Jun 4, 2015 09:29 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:33 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
