Camaro SS rims
Old Jun 16, 2006 | 05:22 PM
Bobsep84's Avatar
Camaro SS rims
I was wondering if the LS1 camaro ss rims would fit on my 95 z28.
Old Jun 16, 2006 | 05:58 PM
fragenstein's Avatar
Re: Camaro SS rims
Should be direct swap. I have 98 Z28 wheels on my 93 TA
Old Jun 16, 2006 | 05:59 PM
Greed4Speed's Avatar
Re: Camaro SS rims
Read the sticky!
Old Jun 16, 2006 | 06:16 PM
69gto96z's Avatar
Re: Camaro SS rims
Yes they will. you will have to make the center where the wheel fits on the hub slightly larger for the rear though. I used a dremel tool. The hubs on the 93-96 F-Bodys are slightly larger in the rear than the front.
Old Jun 17, 2006 | 11:34 AM
Re: Camaro SS rims
You sure it isn't the other way around? I could swear my fronts go on the rear, but the rears won't fit on the front.
Either way... at MOST you'll have a LITTLE filing to do (like 1mm). Go for it.
Old Jun 19, 2006 | 01:33 AM
Bobsep84's Avatar
Re: Camaro SS rims
Sweet, now i just have to start lookin on ebay for a set....how much do they normaly run for a set?...Also, if i mounted 315/35/17 tires on the ss rims, would it rub anywhere?
Old Jun 19, 2006 | 02:13 AM
Aklaim's Avatar
Re: Camaro SS rims
That is too wide of a tire for the size of the rim. go down to a 275 or a 285 at the absolute max. But even then, i still think that a 285 is too large. If you want to run a 315 then you need to get an 11" wide rim.
Old Jun 19, 2006 | 11:33 AM
Re: Camaro SS rims
Yeah NO 315's... are the SS rims 16x8 or 17x9.5? I really can't remember. If they are 16x8, no higher than 255s... if they are 17x9.5, no higher than 285s.
Old Jun 19, 2006 | 12:00 PM
Dave '97 Z28 M6's Avatar
Re: Camaro SS rims
Factory SS wheels are 17x9". 275/40 is the most appropriate tire size, and also the same size that was installed on them at the factory.
Old Jun 19, 2006 | 11:16 PM
Mr Z28's Avatar
Re: Camaro SS rims
SS wheels were 17x9 on coupes, but 16" SS style wheels came on some convertibles - be careful on Ebay
Old Jun 20, 2006 | 03:37 AM
Aklaim's Avatar
Re: Camaro SS rims
The SS ten spoke, only came in a 17"x9".
Old Jun 20, 2006 | 11:17 AM
Re: Camaro SS rims
Yeah, the "ZR1-style" SS wheels for the LT1 SS cars were available in a 16x8 version for the 'verts. But I've only seen the 10-spoke SS wheels in 17x9.
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
turbo_Z
Aug 19, 2002 10:50 PM
