C5 Magnesium Wheels 18x9.5
Old Feb 2, 2010 | 08:41 PM
renkier's Avatar
Will these fit a 4th gen without a BFH? I think they have a 65mm offset which would normally be to much for a 9.5 in wheel, right? I found this article where they are on a firebird and they fit fine: "The wheels fit perfectly," says Murphy. "The offset was just right. Those wheels look great on an F-car."
http://highperformancepontiac.automo...ion/index.html
Old Feb 2, 2010 | 10:58 PM
Are you using them in the back only, or on all 4 corners?
In the front, 56mm works on a 17x9.5" wheel. You will probably get away with a bit more offset (= more backspace) on an 18x9.5" wheel, since as you move further from the spindle, the steering knuckle is curving inwards toward the engine. Whether the spindle curves back enough (0.35"), I don't know. The wheels will sit deep in the wheel well.
In the back, it shouldn't be a problem. The backspace is ~7.78", and that's about 0.15" less than the sometimes problematic 7.93" backspace ZR1/GS wheels.
Gonna be close.
Old Feb 2, 2010 | 11:49 PM
bluz28's Avatar
If that's the actual offset of your wheels then you'll need a 20-25mm hub spacer, which will set the wheels out far enough but not give you any problems(effective offset of +45 w/20mm hub spacer, and +40mm w/25mm hub spacer).
Old Feb 3, 2010 | 06:12 PM
renkier's Avatar
Ok, thanks.
I was planning on using the 18x9.5 on all four corners since i found some brand new wheels for $250 each. Seems like too good of a deal to pass up and i love these wheels....how reliable are spacers?
Old Feb 3, 2010 | 10:57 PM
Before you go buying spacers, mount the wheels and see how they fit and look. If you decide you want to push the wheels out 1" for a more aggressive look, you wouldn't buy a "spacer", you buy an adapter that bolts to your wheel studs, and has a 2nd set of studs that the wheels bolt to. For years I've recommended Skulte for those adapters, but thye have ceased production.
Old Feb 3, 2010 | 11:15 PM
bluz28's Avatar
You want something like this if your post wheel offset is correct.
http://www.importrp.com/files/images...drm-spacer.jpg
BTW, H&R makes good Hubcentric Hub spacers in a 20-25mm sizes.
Old Feb 4, 2010 | 12:38 AM
renkier's Avatar
Where is a good place to get H&R wheel spacers, or wheel adapters? Lots on ebay, but not sure of the quality?
Old Feb 4, 2010 | 11:50 PM
renkier's Avatar
i was able to finally find some spacers/adapters, thank you to everyone for your help in answering my questions
Old Feb 10, 2010 | 07:07 PM
bluz28's Avatar
Thumbs up
Post some photos up after you get everything installed.
Old Feb 10, 2010 | 08:37 PM
renkier's Avatar
actually, i finally decided not to get the wheels because i didnt feel comfortable using 4 spacers. but.....i just ordered some centerline retros which i will post pictures of when they are on the car!
fyi: smcperformance.com has 8 18x9.5 brand new never mounted C5 magnesium wheels for $250 each
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
