Anyone have these?
Anyone have these?
BFGOODRICH G-FORCE T/A KDW 2??And whats your opinion on them.And also 255/40YR17 does anyone know if they will rub my ground effects?
Re: Anyone have these?
what are the specs on your wheels? 255 seems a bit narrow for what people upgrade with.
as far as the tires, known to be noisy from my friends perspective. some people are please with the traction. my customer with an 03 cobra is, but of cource, they arent a drag radial
Go to Tire Rack, click on "tires by size", put in 275/40-17. When you get the list of avaialble tires..... more than 40.... for each tire you will see a "survey" button. Click on the survey button, and you get a consumer rating survey, showing how the tire is rated for dry traction, wet traction, cornering, noise, ride comfort, tread wear, etc. At the bottom of the survey screen is a button that allows you to compare the specific tire you are looking at to all similar tires.
