Another Wheel Backspace Question
Old Apr 13, 2007 | 08:22 AM
RKHiPerformance's Avatar
We're about to replace the stock wheels on my Dad's '02 SS with an aftermarket set, sized 17x9.5" all around.
I think the backspace we're after for this application is 7", but a search I performed showed only offset recommendations in millimeters.
Can someone please confirm that 7" is indeed the correct backspace for this application?
Thanks very much,
Rick
Old Apr 13, 2007 | 09:42 AM
Moshbmx1's Avatar
6.95 is the backspace recommended in the FAQ at the top of this page
I pulled this off the FAQ:
" As the wheel diameter increases, you can go to a larger backspace without hitting the steering knuckle. The knuckle slopes "back" from the spindle as you move upward on the knuckle. While a 17" wheel may be limited to a 7.45" backspace, you can use a slightly larger backspace on an 18" wheel"
Old Apr 13, 2007 | 10:45 AM
The number quoted in millimeters is the "offset", not the backspace. You want an offset in the range of 45-56mm for a 9.5" wide wheel. The stock WS6/SS 17x9.0" 50mm offset wheels have a backspace of a shade under 7.0". A 9.5" wide wheel with a 56mm offset has about a 7.40" backspace.
The relationship of backspace to offset is affected by the size/shape of the lip that holds the tire bead on the rim. Offset is a precisely defined number. Backspace will vary slightly from manufacturer to manufaturer, or even among different wheel designs from the same manufacturer.
Ken Cemo
Feb 13, 2015 08:37 AM
Airplanedoc
Feb 1, 2015 07:14 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
ChrisFrez
Nov 30, 2014 08:41 AM
JoshGuitar
Jul 23, 2002 06:20 PM
