ADR 18 INCH RIM help
Im thinking about getting some 18's for my 94 z28 and i just wanted to make sure the offset would be right, They are 18x9 with ofset of 45mm. Lug pattern 5x120. I know 4.75 converts too 120.6 maybe but I just wanted to make sure they would fit proper before i bought them. Also i would be runninig 275-35-18 tires or 265/35/18 any help or reccomendations would be great. Thanks
Re: ADR 18 INCH RIM help
this is highly argued about
best to stick with the correct bolt pattern. otherwise, if you are to have a wheel off and cause some damage, you will be held liable for having improper sizing
and use the 275/35/18
I HAVE them.....and they fit great...no complaints here.
400rwhp and haven't broke anything yet.
You can see how they look/fit here: http://www.cardomain.com/ride/692233
And I used BFG G-force sports tires 275/35/18's.
Originally Posted by Kents_504
Gone, where did you get those wheels!!! Size and specs(backspacing) would be great too. Nice looking car btw
E-bay.
$925 to my door if I remember correctly.
I have no idea on the backsapcing, you'll have to check it out yourself on ADR's website.
They are 18x9.5 on all 4 corners.
