315's whatdo i need to do?
Old Jun 29, 2004 | 01:25 AM
ARTIC_Z's Avatar
i just got 315 bfg drag radials and i know my friend had to cut something off in the fender to put his on but its lowerd. is there andthing that needs to be trimed or removed? thanks
Old Jun 29, 2004 | 10:27 AM
Black_Z28's Avatar
You may or may not need to do any work on your car. All cars are different, so it all depends. But you'll most likely need to grind down the bumpstop and bang the inner fender wall a little bit. Just put the wheel with the tire on and mark the locations where the tire is near the inner fender.
Old Jun 29, 2004 | 02:38 PM
Red95M6Z28's Avatar
If the wheels are 11"wide and 50mm offset you will have some rubbing on the inner wheel well. I should take pics I guess. You need to drive it for 50-75 miles and then jack the car up and look where they rub. Be sure and hit some hard corners to make sure you get the most evidence of rubbing. Grab a rubber mallot and bang hard.
Old Jun 29, 2004 | 07:00 PM
TriPinTaZ's Avatar
i just added 17x11 ZR1's to my car in the rear. The are 50 MM offset. I had the bumpstops cut completely off the car and did not have to do any hammering to the fenderwells.
I have 315/35 Nitto DR's. NO rubbing problems
Old Jun 30, 2004 | 01:51 AM
ARTIC_Z's Avatar
there 17x9.5 zo6's with 275 front with the 315 bfg's in back im getting them from a friend that has a 96 z28 and he said he didnt do anything but they do rub
Old Jun 30, 2004 | 02:30 AM
Zack's Avatar
315 on a 9.5 in wheel? i feel bad for the guy that mounted that
Old Jul 1, 2004 | 03:16 PM
ARTIC_Z's Avatar
ok well there on and i let them rub awile then took them off and banged in the spots that were rubbin and it seems and looks like its also rubbin the acual lip of the finder that folds under. can i just cut or trim that lip off?
Old Jul 1, 2004 | 03:39 PM
Red95M6Z28's Avatar
Read this!
http://u2.netgate.net/~jshapiro/z28/315s/index.html
Old Jul 2, 2004 | 01:11 PM
ARTIC_Z's Avatar
thank you that helped alot.
chuck
Mar 31, 2003 09:58 PM
stik6shift00
Mar 5, 2003 08:34 PM
JTS95TA
Jan 28, 2003 05:43 PM
COMNBYU
Dec 12, 2002 07:31 AM
RS Dragster
Nov 14, 2002 05:09 PM
