315's on 10" wheel according to tirerack
Old Dec 13, 2004 | 12:43 AM
TireMarx723's Avatar
the sumitomo htr z and the dunlop 315/17/35...are listed as able to fit a 10" min wide wheel..i thought 10.5 or 11" was the min?? do these tires run just a little smaller? can any1 chime in?
Old Dec 13, 2004 | 03:46 AM
n2oblkz
Guest
Posts: n/a
Re: 315's on 10" wheel according to tirerack
No, they are not smaller. I have the HTRZ's on my car with 17X9.5 inch rims and they are wide. The only 315 tire that I know of that is smaller is the Nitto Drag radial in 315. You will be fine with a 10" wheel.
Old Dec 13, 2004 | 12:29 PM
The minimum rim width is determined by the manufacturer. It can even vary for the same size tire from the same manufacturer in two different "lines". Compare the Goodyear GS-D3 (10.5" min.) to the Goodyear Eagle F1 Supercar (11.0" minimum). Dunlop seems to accept a narrower width than the other manufacturers.
Old Dec 13, 2004 | 01:56 PM
Kataklysm's Avatar
When I bought my car it had 315s on a 9 inch wide wheel out back Other then it rubbing the inner well there was no problems.
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
Ken Cemo
Apr 15, 2015 09:41 AM
Ken Cemo
Feb 13, 2015 08:37 AM
