295/35/18
Old Jun 9, 2008 | 05:34 PM
  #16
slomarao's Avatar
Ill measure a rim when I get the car back. Opti went after 117k. I thought i was lucky because i had it so long. Doing the waterpump too while im at it.
Good tip N2ceptor, thanks.
Old Jun 13, 2008 | 04:14 PM
  #17
MislMan's Avatar
JUST FOR MEASURING. DO NOT DRIVE CAR WITH THESE PARTS INSTALLED.
Buy a hand full of 1/2" washers from Home Depot and use those.
- Remove the wheel
- Place 1 or 2 washers on each wheel stud
- Install wheel on car
- Lower car to ground (weight on wheels)
- Firmly tighten lug nuts
- Check wheel and tire for clearance
- Remove or add washers until you have the clearance you need
- Remove wheel
- Remove washers and note how many were needed
- Measure height of washer stack
- That is the size spacer you need
I recommend putting the car on some 2" high x 12" wide pieces of wood planking for the fit check. This extra clearance allows you to het your head under the front of the car to check clearances.
Later ... Larry S.
shawngamblez28
Apr 24, 2011 08:59 AM
canbaufo
Wheels and Tires
Mar 26, 2011 01:37 PM
BlowBye
Parts Wanted
Jul 28, 2004 09:58 PM
BlowBye
Jul 28, 2004 06:06 PM
Asskikr
Sep 25, 2003 02:38 PM
