225/35/18??? is this right
Not only is a 225/35-18 too narrow for a 9.5" rim, it is also too small in diameter..... about 1-1/2" smaller than the stock tire diameter. Your speedo will read almost 4MPH faster than actual speed at a true 60MPH. The car will lose .75" of ground clearance, and the already huge gap between the top of the tire and the fender opening will increase by another .75"
Looking at the specs on Tire Rack, I didn't see any manufacturer that would recommend that tire for a 9.5" wide wheel. Most use it on a 7.7-9.0" wide wheel. You need to look at a 245/40, 265/35 (8.0-9.5" width) or a 275/35 (9.0-11.0" width) to get the right diameter.
