20" Rim Question
Old Aug 20, 2004 | 10:32 AM
jy211's Avatar
20" Rim Question
those of you with 20's all the way around, what's the widest width can you run? What's the right back spacing? Can you run a 10.5 all the way around? Did you lower your car? What size springs? Also what size tires are you running?
Old Aug 21, 2004 | 10:33 AM
Z Power's Avatar
Re: 20" Rim Question
Well, from my limited knowledge, yes you can run 10.5 all the way around. Yes, it can be lowered. And most people run 275/35s or 285/30s, the biggest i've seen is 295/40s (rear size tires of a Prowler) and just about everything else are truck tires
Old Aug 23, 2004 | 08:17 AM
jy211's Avatar
thanks....
Old Aug 25, 2004 | 10:13 AM
ree9c1's Avatar
I have a set of 20X9.5 rims & tires(275/35/20). Will these fit without any modifications? I'll be using adapters because the bolt pattern is different.
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
