19X10 All Around - Injuneer Help!
Old Mar 23, 2006 | 03:49 PM
Faccnator's Avatar
I want to put 19X10's on the front and rear of my 95 Z28. What offset/backspace do you recommend? What size tires do you recommend? I want to make a purchase this week. Thanks in advance for the help!
Faccnator
Old Mar 24, 2006 | 11:09 AM
Re: 19X10 All Around - Injuneer Help!
I'd guess that you need a 50mm offset. That would keep the backspace small enough that they wouldn't rub on the steering knuckle in the front, and keep the "front space" down where is will not stick out of the front fender. Should look OK in the rear.
I have no experience with 19" wheels.... since the steering knuckle is angled back as it goes up, the larger diameter wheel may be able to use a deeper backspace. And I can't guarantee you the fender won't rub on the tire with a 10" wide wheel in the front.... I have only used 9.5's in the front.
But overall, that would probably give you the best balance on the way they fit in the wheel wells.
Old Mar 24, 2006 | 11:37 PM
chuckys95's Avatar
19x10 all around
Old Mar 28, 2006 | 03:02 PM
Faccnator's Avatar
Chucky,
Those wheels look great, your car has always been an inspiration to me. What is your offset, yours look perfect.
Thanks,
Faccnator
Injuneer
Apr 25, 2022 06:22 PM
Novo
Jun 14, 2016 02:58 AM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
Capt'n Two Rotors
12
Jan 27, 2005 01:14 PM
