1995 Camaro Z28 rim question
Im getting ready to buy rims for my 95. I'm looking at 18x10.5" for the rear wheels with a 295/35/18 tire. Anyone think I'll have problems with these fitting on the back, and will I need a wheel spacer?
These are the wheels I'm looking at
Re: 1995 Camaro Z28 rim question
Whether they will fit, and whether you need a spacer depends on the OFFSET. If the offset is too large, the inside edge of the tire is up against the inner fender. If the offset is too small, the outside edge of the tire is against the fender lip or outside the fender. No one can tell you they will fit correctly without knowing the offset. There is a guide to wheel width vs. recommended offset in the FAQ at the top of the page.
Brandon Wittmer
Dec 3, 2014 09:28 PM
Chrisdude
Jul 24, 2002 02:25 PM
