18x9.5 +49 offset instead of +56
Old Nov 27, 2005 | 12:55 PM
Zack's Avatar
my wheels now are 18x9.5 with a 56mm offset. I Found wheels, same size, but 49mm offset. now I can imagine them working on the rear, but what about the fronts, especially when I lower it. it seems like a tight fit as is and can see where it rubs already
tire size is 275/35/18
Old Nov 27, 2005 | 09:29 PM
Re: 18x9.5 +49 offset instead of +56
7mm is a shade over 1/4". I've run a set of OZ Racing Monte Carlo's, 17x9.5 with a 49mm offset, on all 4 corners, with 275/40-17 tires. There were no rubbing problems of any kind when the car was at normal ride height.
The only time I ever got any rubbing at all is when I temporarily dropped the front end by 1.8". Then the tire would rub in the inner plastic fender liner, IF the wheels were approaching full lock AND I hit a bump at the same time.
Old Nov 27, 2005 | 11:23 PM
Zack's Avatar
thats about when mine now rub on the fronts
looks like i might have a new set of wheels going on
thanks fred
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
