17x11 ZR1s need pictures please...
Old Nov 17, 2004 | 09:20 PM
ABA383's Avatar
I'm looking into getting some 17x11 silver ZR1s for the rear of my Formula. I know that this has been beat to death but a search didn't help a lot. I understand that we should use the 50mm offset, but I also know that a 36mm offset is made as well. Just wanted to see what each offset looks like on our cars. I don't want to bang up the inside of my fenderwell if I can help it. I was also told that non-lowered cars (like mine) can use the 36mm. I just don't want the tire, which will be a 315 BFG DR, to hang out too much...Thanks in advance for any pictures of both offsets on cars...
--Alan
Old Nov 17, 2004 | 11:41 PM
Re: 17x11 ZR1s need pictures please...
17x11 50mm offset, with BFG 315/35-17 Drag Radials:
http://cjcfo.fbody.com/members/injun...C/RrView01.jpg
You might want to try a "search" on the "Appearance" forum. About a year ago, before they split up into the "Wheels & Tires" forum, there was a fairly long thread on "Appearance", with photos showing both the 50mm and 36mm offset 17x11's on Firebirds, and the general consensus was that the 36mm wheels stuck out too far.
Old Nov 18, 2004 | 12:12 AM
jbsupra89t's Avatar
those look great... can't wait to pick mine up
Old Nov 20, 2004 | 10:12 AM
ripitup2's Avatar
I am installling Grandsport offsets on my 1994 Z28 the snubbers are in the way when the suspension tops out what should I do elminate the snubbers?
Old Nov 20, 2004 | 03:27 PM
You don't have to eliminate the jounce bumpers. Just cut/grind off the edge of the mounting bracket that sticks out from the inner fender:
http://cjcfo.fbody.com/members/injun...A/FendMas2.jpg
Shoot a little rubberized undercoat on it after you are done.
Old Nov 21, 2004 | 08:25 AM
INSANEZ's Avatar
go to my homepage. 50mm offset, I had to do a little pounding and had to cut area were bump stops were.
http://www.cardomain.com/id/n_ecstaz
bowtieboy95
Jul 1, 2015 06:49 AM
sloppytot
Feb 25, 2015 08:30 PM
Ken Cemo
Parts Wanted
Jan 28, 2015 09:04 AM
1BADWS6
Sep 12, 2002 08:29 PM
IDOXLR8
Aug 6, 2002 12:30 PM
