17x11 ZR1 rims
Old Jul 24, 2005 | 10:38 PM
Sly_Z_28's Avatar
17x11 ZR1 rims
what tires should i put on them (NO DRAG RADIALS)? I have BF Goodrich 315's on there now and cant get them to fit, i tried grinding the bumper stops and i dont want to use spacers. Any suggestions?
Old Jul 24, 2005 | 10:48 PM
Zack's Avatar
Re: 17x11 ZR1 rims
if you dont want to use them to their full potential with 315's, just get a pair of 9.5 wide wheels
Old Jul 25, 2005 | 09:19 AM
Re: 17x11 ZR1 rims
What part doesn't fit? What is the offset of the wheels?
There are hundreds of people running those wheels with fat 315's, on 4th Gens, so they will fit with the correct offset. You may need to do a little hammering of the inner fenders. If the body is not centered side-to-side over the axle, you might need to correct it with an adjustable panhard rod. Cutting the edges of the jounce bumper brackets of is always a good idea, but only necessary if you jack the car by the body, allowing the axle to go to full drop.
17x11, 50mm offset, BFG 315/35-17 Drag Radial.
Left side:
http://cjcfo.fbody.com/members/injun...C/TirClr2L.jpg
Right side:
http://cjcfo.fbody.com/members/injun...C/TirClr1R.jpg
How does your setup differ from mine?
Old Jul 30, 2005 | 09:17 AM
sir dyno's Avatar
Re: 17x11 ZR1 rims
Left side:
Right side:
How about some pictures of the rear, I'd like to see how wide those tires look in one full picture. Thanks.
Old Jul 30, 2005 | 10:10 AM
Re: 17x11 ZR1 rims
http://cjcfo.fbody.com/members/injun...C/RrView01.jpg
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
scottcba1
Sep 8, 2015 09:52 AM
