17 or 18x11
Old Aug 19, 2004 | 06:02 PM
blind527's Avatar
17 or 18x11
im thinkin about gettin 17x11's or 18x11 wheels. if i got those and slapped on some 295's, will my speedo read correctly???
and does anyone recommend any 17 or 18x11 wheels?? i have a 97 formula.
Old Aug 19, 2004 | 06:58 PM
Re: 17 or 18x11
There is no 295 width available in a 17" tire. You would use a 315/35-17. A lot of us are running those on 17x11 wheels. It is exactly the same diameter as the stock tire and will not affect the speedo.
There are 295/35-18's available, and they will be about 1/2" larger than stock, and cause your speedo to read about 1 MPH low at 60 MPH. An alternative would be a 315/30-18 which is almost exactly the same diameter as stock.
Old Aug 19, 2004 | 07:00 PM
blind527's Avatar
Re: 17 or 18x11
would 315's stick out too far???? i could always get zr-1 wheels, those are 17x11 if im not mistaken, and get some 315's, would that be good?
Old Aug 19, 2004 | 07:03 PM
Re: 17 or 18x11
My 315 BFG DR's on AFS ZR1/GS offset (50mm) 17x11 wheels:
http://cjcfo.fbody.com/members/injun...C/RrView01.jpg
http://cjcfo.fbody.com/members/injun...C/Rr34Dr02.jpg
http://cjcfo.fbody.com/members/injun...osD/SLP27a.jpg
Old Aug 19, 2004 | 07:05 PM
blind527's Avatar
Re: 17 or 18x11
looks sweet ill look into that
Old Aug 19, 2004 | 09:40 PM
Arctic_Z's Avatar
Re: 17 or 18x11
How are you getting a 295/35/18 onthe back of a Z. I'm trying to do this now and they are rubbing. Even with a spacer I can only get a 1/4" space and thats with 10.5" rims.
Old Aug 20, 2004 | 09:37 AM
blind527's Avatar
Re: 17 or 18x11
what is the maximum 17 or 18" wheel and tire size that i won't have any rubbing with????? im just thinkin about 275's on either 17's or 18's, cause i don't wanna have to deal with spacers etc..
im lookin at some 18x9.5's, would i lose speedo accuracy???? what max tire size can i put on these w/o it rubbing?
Old Aug 23, 2004 | 09:31 PM
Johnnynsac's Avatar
Re: 17 or 18x11
I have 18's with 295/35 and have no rubbing. I think some cars are worse then others. There also 10.5
RJBAILEY84
Jul 7, 2012 08:48 AM
pigsticker
Wheels and Tires
Mar 2, 2012 10:24 AM
Bow94z
Feb 16, 2005 09:54 PM
SSiCKSS
Mar 25, 2003 11:34 AM
