10.5X18 ZO6 rims stick past fender?
Old 03-17-2006, 04:10 PM
JONEZ_Z's Avatar
I want to get some 10.5x18 rims for the back and the 9.5x18 in the front. The offset for the 10.5 is 58mm. I know some of you guys have them, do they stick out past the fender? Does anyone have any pics? I had this in the wheel and tire forum but it got no response. thanks
JONEZ_Z is offline
Old 03-17-2006, 04:51 PM
z28_theantirice's Avatar
Re: 10.5X18 ZO6 rims stick past fender?
that is the same offset and rim I have, unfortunatly I dont have mine on my car yet, but with the 58mm backspacing they wont stick outside of the fenders
z28_theantirice is offline
Old 03-17-2006, 05:04 PM
firebirdStud's Avatar
exact setup I am running! They tuck nicely in the fenders. No pics, as the crappy stock rims are on it for storage. But, they will work fine. I had to bash in the inner fenderwell on the rears, but did not have to bend the fender lip up!
hope it helps bro!
firebirdStud is offline
Old 03-17-2006, 07:59 PM
street demon2k3's Avatar
if the wheels your gonna get are the stock Z06 offsets, then you should have no problem with them. i just had to hammer the fenders in a little for peace of mind. i have pics in the link that i have in my sig. as well as a pic of my bro.'s Z28 with them as well.
street demon2k3 is offline
Old 03-17-2006, 09:40 PM
Cmr0z28's Avatar
And this relates to LT1 engines how?
Cmr0z28 is offline
Old 03-18-2006, 02:10 PM
TxAgZ28's Avatar
They won't stick out but the inside of the tire will rub without spacers.
This is a factory 18x10.5 '02 Z06 wheel with a 1/4" spacer. The tire is a 305/30/18 Kumho V700. My car is on LG G2 springs.
TxAgZ28 is offline
Old 03-18-2006, 03:46 PM
The 58mm offset puts it really deep in the wheel well. That's why people have had to hammer the inner fenders, or add spacers. If you don't use a spacer, its going to put the tire 1/2" inside the fender when looking straight down from above the fender. Thats 1/2" deeper than these:
Injuneer is offline
Old 03-18-2006, 05:21 PM
teal99camarov6's Avatar
what kind of spacers do I need for my 18x9.5 c5 rims? How much are they.
teal99camarov6 is offline
Old 03-18-2006, 08:37 PM
Zack's Avatar
you shouldnt need any
Zack is offline
Old 03-19-2006, 08:53 AM
JONEZ_Z's Avatar
Thanks guys. I cant wait for my rims to show up.
JONEZ_Z is offline
Old 03-19-2006, 02:30 PM
No one can answer that question without knowing the offset or the backspace of the wheels.
Injuneer is offline
Old 04-11-2006, 01:02 AM
pu12en12g's Avatar
I think my rears were 56mm offset.. see photo for how it lined up with fender.
20 x 10.5 Custom Z06 Wheels on all 4 (First Z28 Convertible to ever have this setup):
http://technologyorgasm.com/upload/pt1.jpg
http://technologyorgasm.com/upload/pt2.jpg
pu12en12g is offline
Old 04-13-2006, 04:53 PM
JONEZ_Z's Avatar
JONEZ_Z is offline
Old 04-14-2006, 02:17 PM
Read the info posted right above the photo of my car....
The 58mm offset puts it really deep in the wheel well. That's why people have had to hammer the inner fenders, or add spacers. If you don't use a spacer, its going to put the tire 1/2" inside the fender when looking straight down from above the fender. Thats 1/2" deeper than these.
They will not stick out past the fender, they will be 1/2" deeper than the tires in my picture. They will probably rub on the inner fender.
Injuneer is offline
Old 04-14-2006, 03:15 PM
JONEZ_Z's Avatar
Well I ended up getting the 18X10.5s with the 58 offset and they dont rub at all. The only thing i did was cut about 1/4" off my bump stop so that i can let my suspension hang at full droop. in case anyone wondered.
JONEZ_Z is offline
Quick Reply: 10.5X18 ZO6 rims stick past fender?
