subframes
subframes
I have some SLP subframes that i need to have welded in. Who can weld them in and does good work and at a reasonable cost? How much does it normally cost? I've heard of people using muffler shops for this task. Im looking for a place in the frisco or lewisville area or nearby. Thanks Bill.
Re: subframes
Its true most muffler shops can do it, but just be careful and ask questions... You dont want "Joe Snuffy" doing a job that he has never done before... Make sure the shop has knowledge of what they are doing.... Cost can range from 30-60 dollars, depending on all that is involved...
Re: subframes
I've been calling around a little bit and it seems like nowone knows what subframes are. One shop said 200 dollars and then i said no way. I'll keep calling but if someone knows a place close to where i said then give me a hollar. Thanks very much, Bill
Re: subframes
I still haven't got them welded in yet. However I also haven't called RPM. I just want someone who will do it for cheap but a good price. I'm sure most people feel the same way. So the answer to your question is no I have not figured it out yet. If you do hollar at me nov194.
Re: subframes
Not sure if this is assumed or not, but also make sure the car is on the ground as not to 'pre-load' the connectors. They should at least tack weld them while the car is on the ground, and then lift it if necessary.
Re: subframes
I got this off of LS1.com:
RPMotorsports
"there's no substitute for RPM"
107 E. Walters
Lewisville, TX 75057
972.434.2151
http://www.real-performance-motorsports.com
Kyle
RUENUF
Mar 13, 2016 03:37 PM
ducttape1975
Jul 10, 2015 06:29 PM
