need clutch/tranny work done
anyone know a good place in SA,preferably, that can do good job with clutch or tranny. I am having lots of problems disengaging my clutch when speed or power shifting, no problems when granny shifting. I think my clutch never got bled properly when installed. I have a SPEC stage 2 clutch. Holds excellent and not clutch clatter or anything just not disengaging quickly. Shoudl I get an adjustable slave or master? Thanks.
Are you running the stock master? Did you do the drill mod to remove the restrictor in the stainless line? That may help on the power shifting. Helped mine on the stock clutch.
2001 Z28, Black, leather and T's.
A few appearance, suspension and engine mods and she sniffs crack!
Pedro, Ezells is working on my clutch. I went with an aftermarket slave that doesn't seem to work well with the mcleod adjustable therefore I may be selling my adjustable master in case you are interested.
If you need someone to work on your car I would contact Richard at Ezells. He knows ALOT about the LS1.
EZELLS AUTOMOTIVE SERVICE & REPAIR
4019 MCCULLOUGH AVE, SAN ANTONIO, TX 78212
(210) 822-9881
Ask them for an estimate.
1998 M6 Z28
2000 Ninja 500R
_ _ _ ____ _ _ _
Bone Stock
San Antonio F-Body Club http://www.sa-fbody.org
HomePage http://www.z28pwr.com
(210) 822-9881
1998 M6 Z28
2000 Ninja 500R
_ _ _ ____ _ _ _
Bone Stock
If it's a bleeding issue, you can do that yourself without doing anything major. Find a lift or put it on jack-stands...look for the braided line that goes to the slave. Just above that is another "hole" in the tranny casing. In this hole is the bled valve for the slave. Bleed it just like you would bleed your brakes. I recently had the same hard shifting problem, but it turned out being a problem with the design of my clutch. Good luck!!
98 WS6 Formula M6
Slammed and Cammed
1980 K-5 Blazer aka "Big Mud"
98 WS6 Formula M6
Slammed and Cammed
squarehead
Jan 15, 2015 07:02 PM
