LT4 engine COMPLETE
Old Feb 15, 2004 | 03:02 PM
'95 LS1 Z28's Avatar
LT4 engine COMPLETE
LT4 heads with Comp dual springs, retainers, & locks
LT4 intake w/fuel rail & stock injectors
BBK 58mm TB
All engine sensors
GM Opti-Spark(not aftermarket)
PCM(programmed to run a 360cid w/LT4 top, CC306 cam, and PT3600 stall converter)
Full engine/tranny wiring harness
360 cid (bored 60 over) 4 bolt main iron block with pistons, rings, rods, crank, and oil pan,
Comp Cams 306 cam 230/244 .510/.540 112lsa
Comp Cams Pro-Magnum 1.6 Roller Rockers
A/C compressor
Alternator (from O'Reillys, 600 miles)
Power steering pump (90k miles)
$4500 Fully assembled and has less than 500 miles on it all.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
