LT4 engine COMPLETE
LT4 heads with Comp dual springs, retainers, & locks
LT4 intake w/fuel rail & stock injectors BBK 58mm TB All engine sensors GM Opti-Spark(not aftermarket) PCM(programmed to run a 360cid w/LT4 top, CC306 cam, and PT3600 stall converter) Full engine/tranny wiring harness 360 cid (bored 60 over) 4 bolt main iron block with pistons, rings, rods, crank, and oil pan, Comp Cams 306 cam 230/244 .510/.540 112lsa Comp Cams Pro-Magnum 1.6 Roller Rockers A/C compressor Alternator (from O'Reillys, 600 miles) Power steering pump (90k miles) $4500 Fully assembled and has less than 500 miles on it all. |
