FS: built 347 ls6 block motor
Old Feb 17, 2004 | 12:58 AM
fastazz98camaro's Avatar
I'm parting my car out so sadly this has to go School is owning me and $$ is tight. This motor was only fired up to ensure there were no problems with it, it has 0 miles.
Ls6 block
Stock crank, rods
Je pistons 11:2 to 1 compression
arp rod bolts
clevite bearings
ported oil pump
diamond pro piston rings
gtp stage 2+ heads (just got a valve job and further port work by "lump" of lump cylinder heads in houston, he does NHRA heads and his partner jeff naiser builds the shortblocks)
MTI R1 cam
asp pulley
ported TB
combination motorsports valvesprings
comp chromoly pushrods
ls6 intake
*No headers included*
This motor will come with EVERY accessorie, waterpump, a/c, radiator, fans, pcm, injectors etc.
Motor made 440rwhp & 415rwtq through a 6 spd, stock ls1 shortblock, w/ a smaller cam (226/226), 10:5 to 1 compression, and before the heads got more work.
Probably forgot a few things, but if there are any questions just PM me or email bad1lez@yahoo.com
$6000.00 OBO
Old Feb 17, 2004 | 12:56 PM
JurisAg02's Avatar
is there a difference between ls1 and ls6 stock rods?
Old Feb 19, 2004 | 09:25 PM
ttt
D1SC383LT4
Jan 1, 2016 01:56 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
hotrodyou1
Dec 20, 2014 10:05 PM
ChrisFrez
Nov 23, 2014 10:33 AM
