Dyno Event in Keller
Old Nov 11, 2008 | 03:53 PM
  #16
2QUIK6's Avatar
Originally Posted by mitchntx
Thanks for answering all the questions.
My plan is to be there early in an attempt to get freshly built car dynoed, and then make it back with my race car before the end of the day. I'm a little over an hour away.
If you care to take a look, here is the freshly built car ...
http://www.lawmotorsports.net/Chassis4.htm
and here is my personal race car.
http://www.lawmotorsports.net/Chassis2.htm
These aren't anything special under the hood. Just a bone stock LT1 making about 250 RWHP. But they are light weight and handle like a go-cart.
Looks like a really nice cage job in that Firebird. A friend of mine autocrosses a '93 LT1 Camaro and a '98 LS1 Camaro that are all basically stock, sounds like the same type of class you run in. I'll keep an eye out for you Sat.
Old Nov 15, 2008 | 06:36 PM
  #17
mitchntx's Avatar
Thanks for the hospitality. Mission accomplished!
Old Nov 15, 2008 | 07:17 PM
  #18
2QUIK6's Avatar
No prob, glad you came out and to have met ya today.
I got home and popped my valve covers off and found 2 rockers on the driver side and 1 on the pass side that the poly lock had backed off of and the #8 cylinder had blown the header gasket out, looks like the rear bolt had loosened up....2 completely unrelated things happening at exactly the same time....at least it nothing serious.
Old Nov 16, 2008 | 07:15 AM
  #19
mitchntx's Avatar
Good to hear it was a simple solution ....
Old Nov 17, 2008 | 11:14 PM
  #20
KyleBlue85Iroc-Z's Avatar
I'm having a funny noise out of the valve covers still that I think is the polylocks backing off....what kind of sound does that make? I just haven't had the time to take off the covers and readjust them.
Old Nov 18, 2008 | 10:02 AM
  #21
2QUIK6's Avatar
Once they get slightly loose, they back off in a hurry because the allen set screw is no longer engaging the stud, so it can spin freely off....but if you have stock height valve covers, usually the lock nut can't back all the way off as it hits the valve cover...mine are close enough that the allen set screw can't back all the way out either as I had one backed into the valve cover gouging it out some.
Its just a loud tick that gets louder as it backs off more. It can sound just like a header leak as well at different rpms....in my case I had both..header leak and loose rockers.
Mine was actually 3 broken poly lock nuts..discovered the cracks in them as I tried to reinstall them Sunday...this is the second time I've broke them...first time was I tightened them too tight...this time they were less than 20ftlbs on the allen lock...so out with the Comp BS and I've ordered some ARPs which have a 190,000 psi tensile strength.... The guy at the speedshop said he had some break on him recently too, so its not just me.
Old Nov 18, 2008 | 05:48 PM
  #22
Damn that sounds like a serious problem! I didn't know those were prone to break. I was running my car hard on the street one night and missed third gear a time or two, so I'm wondering if over revving it caused my issue. I'm not sure the polylocks are hitting the valve covers, because I have already taken it off and messed with two rockers to readjust them and hand checked the others, wouldn't that have been noticable? The noise also goes away at idle when warm, but is noticable when you rev it some.
Old Nov 18, 2008 | 08:09 PM
  #23
2QUIK6's Avatar
If the poly locks were cracked you would have been able to loosen them by hand, no wrench would have been needed. A header gasket leak depending on its severity may only be noticable at certain rpms. Need to carefully feel around for a leak without burning yourself.
fift5
11
Oct 1, 2015 10:31 AM
Louey
Pacific
Oct 1, 2015 12:37 AM
kandied91z
Sep 30, 2015 11:43 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
